Ferreus
#1 Posted : Friday, April 3, 2015 11:31:18 PM(UTC)
Ferreus
Short version: Can anyone provide a schematic or instructions of how the water inlet valve is put together?
This is my first post, so I don't know if the information gets posted automatically, but this is for a GE Nautilus GSC3200G01WW.
Longer version:
- Wife ran the dishwasher and forgot to turn on the water. :(
- As a result, the dishwasher would not drain because the soap was baked and was clogging everything up. Side note: baked soap apparently turns into a type of putty. No bueno.
- I cleaned everything I could (inside, sump housing, etc.) and thought that would fix it.
- Plugged the washer back in, turned it on (with the water this time) and no joy. It was not filling with water.
- I thought, "Hmm, maybe the hoses are clogged." So, took those off and they were fine.
- Then I thought, "Hmm, maybe this little thing where the hose connects is clogged." So, I take off what I now know is the water inlet valve. When I pull it apart, the spring and a little metal rod go flying. :eek:
- Now I can't figure out how to reassemble it. :confused:
- I thought about just buying a replacement part, but the part is more than we paid for the washer. So, I need some help putting humpty back together again.
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve (Washer Repair)
by dcbradt 3/8/2017 4:02:37 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
