fourhagos
#1 Posted : Friday, March 6, 2015 4:47:51 PM(UTC)
fourhagos
My washer made a loud squealing noise and we smelled burning rubber. This was during the wash cycle. I was able to use the spin cycle to empty the water. I checked the belts, which were worn, and replaced both. The wash cycle now wants to run and the agitator only engages if I wiggle the motor. It looks like the springs are fine. Before I wiggled the motor, the motor drive belt would not turn the agitator, but the motor runs fine. Is this a transmission problem? Is there any more trouble shooting I should do? Is it time for a new washer? Thanks for reading.
:confused:
Maytag washer will not agitate (Washer Repair)
by bobneedsadvice 6/25/2012 1:01:25 PM(UTC)
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 4/19/2012 4:55:32 AM(UTC)
Maytag Washer will not agitate or spin (Washer Repair)
by Mbat4 2/13/2012 3:12:24 PM(UTC)
maytag washer will not agitate (Washer Repair)
by renegade107 11/10/2011 7:57:15 AM(UTC)
Maytag washer will not agitate/cold water fill won't shut off (Washer Repair)
by denise2855 8/3/2010 2:14:09 PM(UTC)
Maytag Washer will not agitate but will spin and rinse (Washer Repair)
by pkbeckman 2/23/2009 7:56:44 AM(UTC)
