vykngfan
#1 Posted : Thursday, January 22, 2015 3:56:08 AM(UTC)
vykngfan
My Anana Washer stopped working and shows error code SH. I found out that this is caused by an open thermistor. I unplugged and let the machine rest for 30 minutes and plugged back in. Same error popped up. Is this related to the solenoids in the water mixing valve?
Will replacing this valve correct the problem?
sidfink43
#2 Posted : Thursday, January 22, 2015 5:13:01 PM(UTC)
sidfink43
Check to see if there is a thermistor on the valve assembly and if so that is likely the problem. When you order the part make certain you get the right one for your model and serial number.
vykngfan
#3 Posted : Friday, January 23, 2015 3:05:04 AM(UTC)
vykngfan
Not quite sure what a "Thermistor" looks like but will open it up and check.
Thanks for the reply!!
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Samsung Error Code (Oven Repair (including Ranges and Cooktops))
by Guest 11/6/2023 12:46:38 PM(UTC)
Kenmore OL Error Code (Washer Repair)
by Guest 10/27/2023 8:37:16 PM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Kenmore Elite F09 error code (Washer Repair)
by dieselgg 10/19/2023 4:01:12 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Error code SY EF (Refrigerator & Freezer Repair)
by Guest 7/17/2023 1:05:46 PM(UTC)
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
KitchenAid Error Code 6-1 (Dishwasher Repair)
by JBishop 4/7/2023 12:37:12 PM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
Kennmore Elite Top Load Washer - MHK62125813 - Error Codes (Washer Repair)
by maxxam864 1/4/2023 12:11:00 PM(UTC)
Control board for Frigidaire Affinity dryer (E68 error code) (Appliance Parts)
by VanFramez 12/18/2022 11:57:30 AM(UTC)
