My Anana Washer stopped working and shows error code SH. I found out that this is caused by an open thermistor. I unplugged and let the machine rest for 30 minutes and plugged back in. Same error popped up. Is this related to the solenoids in the water mixing valve? Will replacing this valve correct the problem?
Check to see if there is a thermistor on the valve assembly and if so that is likely the problem. When you order the part make certain you get the right one for your model and serial number.
Not quite sure what a "Thermistor" looks like but will open it up and check. Thanks for the reply!!
