would like to know what causes water to seep in after dishwasher is completely done and not on.
If the water is clean and warm/hot then your water valve is probably not sealing correctly and should be replaced. I believe the following is the correct valve for your unit. Part number: AP2135535
If the water is soapy/dirty then it could be a problem with the drain hose set-up. |
THIS FORUM IS DEAD!!!!!!! |
