sstroman@comporium.net
#1 Posted : Saturday, January 10, 2015 6:36:03 AM(UTC)
would like to know what causes water to seep in after dishwasher is completely done and not on.
#2 Posted : Saturday, January 10, 2015 8:35:51 AM(UTC)
If the water is clean and warm/hot then your water valve is probably not sealing correctly and should be replaced.
I believe the following is the correct valve for your unit.
Part number: AP2135535
If the water is soapy/dirty then it could be a problem with the drain hose set-up.
