Dsteve
#1 Posted : Monday, November 10, 2014 5:41:47 PM(UTC)
Dsteve
The microwave has been working fine. Tonight when we opened the door it made a buzzing sound when the door was shut it quit. Then when we opened the door the light no longer worked. It still heats but the turntable no longer turns and there is a loud bussing coming from behind the upper part of the control panel. I turned the turntable off and the buzzing continues. I also unplugged the stirrer motor and the buzzing continues. Any ideas where I should start looking for the problem?
Dsteve
#2 Posted : Tuesday, November 11, 2014 9:00:19 AM(UTC)
Dsteve
one other thing. When I turn the night light on it also makes the same buzzing sound without the microwave running. Today we were using it and it completely shut off and seemed dead. Later it came on with the same buzzing sound but still no turn table or light inside the microwave. Last night when I had the cover off it I noticed the cooling fan wasn't running. Is it supposed to run all the time or shut off and on during use?
Dsteve
#3 Posted : Thursday, November 13, 2014 4:14:24 AM(UTC)
Dsteve
Does this sound like a board problem and if so can you repair the board?
GE Spacemaker xl1800 vent fan not working (Microwave Repair)
by titannero 1/11/2013 6:27:35 AM(UTC)
GE Spacemaker XL1800 - Making Buzzing Noise (Microwave Repair)
by bunk60 7/20/2011 2:07:03 PM(UTC)
GE Spacemaker XL1800 running when you open door (Microwave Repair)
by andreah 6/30/2011 9:00:53 AM(UTC)
GE Spacemaker XL1800 (Microwave Repair)
by Louisle16 6/28/2011 11:13:46 AM(UTC)
GE Spacemaker XL1800 won't heat (Microwave Repair)
by doanhtran@gmail.com 4/12/2011 11:31:47 AM(UTC)
by sman2626 1/11/2011 6:48:59 PM(UTC)
by guilty 11/25/2010 5:17:36 AM(UTC)
Ge spacemaker xl1800, Fan motor, light and table not working (Microwave Repair)
by mdorsey 10/22/2010 5:23:57 AM(UTC)
GE Spacemaker XL1800 hum/buzz noise but heating works (Microwave Repair)
by faraday 4/11/2009 8:08:15 PM(UTC)
GE Spacemaker XL1800 control panels locks up (Microwave Repair)
by usd777 4/6/2009 7:53:02 AM(UTC)
GE Spacemaker XL1800 will only heat when vent fan is on (Microwave Repair)
by melissams17 3/15/2009 2:34:21 PM(UTC)
GE Spacemaker XL1800 microwave making fluttering sound on startup (Microwave Repair)
by madhuvan 3/9/2009 10:23:07 PM(UTC)
by gotkwah 11/4/2008 4:18:35 AM(UTC)
GE Spacemaker XL1800 stopped heating and awful smell (Microwave Repair)
by perplexed 12/26/2007 12:20:01 PM(UTC)
