melissams17
#1 Posted : Sunday, March 15, 2009 2:34:21 PM(UTC)
melissams17
The writing on the microwave is a little unclear. You can still make out what it says but it takes an extra second or two for your eyes to focus in. More importantly, I can only heat things when the vent fan is on. If it is off, nothing will warm up.
#2 Posted : Monday, March 16, 2009 4:10:13 PM(UTC)
Most likely the problem is a bad control board (aka a smart board).
- The part number for the control board is AP3203496
Here are the break down diagrams and Replacement parts for GE JVM1850CH02 | AppliancePartsPros.com
melissams17
#3 Posted : Monday, March 16, 2009 4:50:24 PM(UTC)
melissams17
How hard is it to replace that?
#4 Posted : Monday, March 16, 2009 5:02:35 PM(UTC)
This job is not too difficult. Just remove the top grille and open the control panel. Look into the diagram.
mdhs84
#5 Posted : Sunday, March 21, 2010 10:46:31 AM(UTC)
mdhs84
I'm having the same issue as Melissas17 with the sam model microwave, and I replaced the control board as suggested. Unfortunately, this didn't correct the problem; microwave will only heat when the vent is running. Any other ideas as to the cause of this problem?
#6 Posted : Monday, March 22, 2010 1:56:22 PM(UTC)
What will happen if you start the microwave without the vent?
mdhs84
#7 Posted : Tuesday, March 23, 2010 3:42:40 PM(UTC)
mdhs84
When I run the vent, the microwave heats the contents without a problem. If I don't run the vent, the microwave doesn't heat anything. Everything else will work; light and turn table, but just no heat.
duralej
#8 Posted : Wednesday, April 20, 2011 3:48:58 PM(UTC)
duralej
Wondering if anyone was able to resolve this issue. I am having the same problem with my 1.5 year old unit...
