pjjensen
#1 Posted : Wednesday, September 24, 2014 1:25:24 PM(UTC)
pjjensen
i recently picked up another whirlpool quiet partner ii off of craigslist for really cheap. According the owners everything worked fine. I already had another qp 2 but with a bad touch panel and it was well abused before we moved in. I installed the one from craigslist, it starts up and runs but will not drain. The cancel/drain button doesn't operate. The led will not light up, when its running it does not try and drain. It just goes back into whatever cycle it is on. I was able to get it do a reset by heated dry/normal. Unfortunately I did not take notice if the cancel LED lit up with all the others or not. Have not been able to repeat the reset since. I also unplugged the touch panel harness from the control board and put power back on and the dishwasher did not run(which i believe points to a faulty control board?) Just wondering where to go from here?
Before I installed the craigslist dishwasher, I initially installed the control panel(touch pad) only on my old unit. It ran but would not drain and performed the same way as it is now. So i figured maybe my control board was bad, so i installed the whole unit.
Also, I did take the control panel off the craigslist unit and ohmed out the wiring harness at connections P1-12 and P1-3. According to the diagnostics it said it should go from infinity down to a readable level. I didn't write down the numbers I got but I believe they were in the 2.2M ohms.
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner II DU1145 (Dishwasher Repair)
by Guest 3/25/2021 6:39:10 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner II Model DU1055XTVQ8 (Dishwasher Repair)
by mgandhd 4/29/2020 9:16:12 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet Partner II (Dishwasher Repair)
by dresstheman 12/30/2017 5:17:12 PM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool quiet partner ii won't start (Dishwasher Repair)
by Mac m 1/6/2015 5:53:21 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
