CaptainChris
#1 Posted : Tuesday, September 16, 2014 12:33:21 PM(UTC)
CaptainChris
I have a GE stack unit that began making a loud noise then the tub locked up and smoked the belt. I replaced the belt and lubricated the bearing. It seemed to work ok on light loads but locked up and burned the belt up on a full load.
What do I need to replace other than the [COLOR="DarkRed"]bearing[/COLOR]? I haven't done anything this major on a washer before. The unit has some age but seemed to work great before this happened.
sidfink43
#2 Posted : Tuesday, September 16, 2014 4:13:06 PM(UTC)
sidfink43
You can try replacing the bearing but given your symptoms I think it is more likely that the transmission is failing, and given the cost of a new one unfortunately you are probably better off replacing the unit.
Hopefully you can get buy with single units as these combo's are expensive.
I am linking you to a service manual for your machine. Yes it is a Frigidaire.
http://www.emaservicetips.com/pdfs/488_3.pdf
CaptainChris
#3 Posted : Wednesday, September 17, 2014 10:47:27 AM(UTC)
CaptainChris
Thanks. New unit ordered today!!
GE washer noise during agitation (Washer Repair)
by nikkibee 5/9/2016 10:54:51 AM(UTC)
GE Washer Noise/Squeaking (Washer Repair)
by utexas22 11/18/2013 11:29:09 AM(UTC)
GE washer noise (Washer Repair)
by hotbox 8/10/2010 12:23:55 PM(UTC)
