WetClothes_WifeUnhappy
#1 Posted : Monday, September 15, 2014 4:19:43 PM(UTC)
My dryer stopped working. When you hit the power button it just buzzes unless you give the drum a little push. When you give the drum a push the motor finishes starting but it doesn't tumble for very long. There seems to be a ton of tension when trying to spin the drum. The belt is not broken.
Rollers?
Kenmore 500 seris (Dryer Repair)
by Guest 4/24/2024 4:34:41 PM(UTC)
motor coupling on top loader kenmore 500 (Washer Repair)
by gabslms 5/22/2021 5:04:32 PM(UTC)
Kenmore 500 Series Top Load Wash Mod #110.25132411 Rinse Cycle (Washer Repair)
by Robdenisse 9/16/2019 10:44:56 AM(UTC)
Kenmore 500 Series Top Load Wash Mod #110.25132411 (Washer Repair)
by Robdenisse 9/16/2019 10:43:11 AM(UTC)
Kenmore 500 Washer - No Warm (hot/cold work) (Washer Repair)
by Old&Slow 6/17/2017 2:17:04 PM(UTC)
Kenmore 500 Series won't drain - NOT the lid switch (Washer Repair)
by mhusk 9/18/2016 6:57:45 AM(UTC)
Kenmore 500 Won't Spin or Drain (Washer Repair)
by Devilsolsi 9/30/2015 6:21:12 AM(UTC)
kenmore 500 washer (Washer Repair)
by dvazquez 10/25/2014 11:40:04 AM(UTC)
sears kenmore 500 stopped working! (Washer Repair)
by sherry0126 5/14/2014 3:12:02 PM(UTC)
kenmore 500 won't drain! (Washer Repair)
by cmeberlin 1/10/2014 12:22:41 PM(UTC)
Kenmore 500 dryer clothes hot, but damp??? (Dryer Repair)
by TJroune 4/26/2013 9:07:54 PM(UTC)
Kenmore 500 series dryer timer/heating problems (Dryer Repair)
by Davy99 4/1/2012 7:23:12 AM(UTC)
Kenmore 500 will not fill with water. (Washer Repair)
by joshgeiger15 11/13/2011 10:42:46 PM(UTC)
Kenmore 500: spin cycle works when empty, does not work when full (Washer Repair)
by silv50 8/23/2010 4:57:26 PM(UTC)
Kenmore 500 disposer runs but blades not moving (Garbage Disposer Repair)
by krissyjo48183 2/27/2010 6:42:38 AM(UTC)
