krissyjo48183
#1 Posted : 15 years ago
krissyjo48183
Hello,
I have a Kenmore 500 Disposer 175.66554. I was running it the other day and the motor runs but the blades in the sink don't turn.
Is there a jam nut I can tighten or is it just time to replace the Disposer? I have never done this type of job and didn't want to jump in blind.
If I have to replace it will I have to rework the drain pipes or are most disposers the same? Will be be an easy replacement? I am good with tools and know basic electrical as the motor is hard wired. My only concern is if I will have to redo the drain system.
Any help will be greatly appreciated...
txrott
#2 Posted : 15 years ago
txrott
At the age you describe, best to just replace.. If you arent mechincally inclined, would'nt attempt replacing it.
