AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore 500 Series Top Load Wash Mod #110.25132411 Rinse Cycle
After I set my washer to do a load, it fills with water, agitates, all like normal. Then it drains the water, but when it goes to the rinse cycle the rinse light just blinks and the washer won't continue through it's cycle. I ran Diagnostics mode and it appeared to run through all the tests as it didn't stop anywhere and just went until complete. What could be the cause of this?
Washer Repair
