agdodge4x4
#1 Posted : 11 years ago
agdodge4x4
106.54619300
Basically, the freezer has ice and it fine but there is no air coming out of the little chill zone or holes between the fridge and freezer.
What I know is that the fan for the coils inside is running.
There is ice on the coils inside. When running the diagnostics on the control board, the defroster for the coil functions.
The damper test opens the damper 1/2-3/4 at the most, and then closes completely, and then opens again...no problem, but it never opens 100%. Not sure if its supposed to open all the way or not.
Thermistors (the ones on the damper) both tested out a 2.7 or thereabouts at room temp.
How do i figure out why the fridge is not cold with this info?
bfridge
#2 Posted : 11 years ago
bfridge
It sounds like it may be a problem with your damper. However, when you say that there is ice on the coils, how much ice is it?
agdodge4x4
#3 Posted : 11 years ago
agdodge4x4
This much
imgur: the simple image sharer
It's enough that the air and fan change sound when you take the cover off. Not much airflow with that ice in it.
#4 Posted : 11 years ago
Don't see an ice clog in the pictures. If no air is going to the fridg section, check the air returns for an ice jam.
Also, measure the freezer temperature and post.
agdodge4x4
#5 Posted : 11 years ago
agdodge4x4
Really? The lower part of the coil is solid ice from fin to fin. That's normal? If so, then Ill order the damper and try it out. Right now, the fridge is set to 33 and it is 61 in there....but the dampers are completely closed for whatever reason.
The freezer temp according to my thermo probe is 7 degrees. Laying on the coil its well into the negatives.
#6 Posted : 11 years ago
If the damper will move open and closed, it's probably ok. I would suspect a bad control or the fresh food thermistor.
agdodge4x4
#7 Posted : 11 years ago
agdodge4x4
I guess Ill order a refurb control board then because the thermistor tested out at the right resistance for room temp according to what i read.
agdodge4x4
#8 Posted : 11 years ago
agdodge4x4
I got a new 'damper'. Upon testing, the new one DOES open 100%. I installed it. Its a REALLY tight fit, but it does fit. This morning the temperature in the fridge was 34, the setting it set to 33, so, I guess it is functioning properly now. Im going to monitor for a few days to make sure though.
Thanks for the help!
freezer cold,fridge not cold enough (Refrigerator & Freezer Repair)
by BSTrue 6 years ago
Fridge Not cold enough (Refrigerator & Freezer Repair)
by water101 7 years ago
Kenmore fridge not cold enough (Refrigerator & Freezer Repair)
by benbenherenow 10 years ago
Fridge not cold. Freezer ok (Refrigerator & Freezer Repair)
by PURCHIARONI@ATT.NET 10 years ago
Freezer fine, Fridge not cold (Refrigerator & Freezer Repair)
by WWats004 10 years ago
Freezer & Fridge not cold - coils cold, evap fan works but not running (Refrigerator & Freezer Repair)
by bootpdx 10 years ago
Kenmore freezer cold, fridge not cold (Refrigerator & Freezer Repair)
by bc. canuck 11 years ago
SxS fridge not cold & shuts off (Refrigerator & Freezer Repair)
by 77bravo 11 years ago
Freezer frosting over, fridge not cold (Refrigerator & Freezer Repair)
by spowel007 11 years ago
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 12 years ago
Frigidaire Freezer working, Fridge not cold (Refrigerator & Freezer Repair)
by jalill 12 years ago
Freezer vents covered with ice/ fridge not cold (Refrigerator & Freezer Repair)
by amytorp 12 years ago
frezzer back freezing up- fridge not cold (Refrigerator & Freezer Repair)
by murphy7513 13 years ago
kenmore - Freezer and Fridge not cold (Refrigerator & Freezer Repair)
by srinia 13 years ago
fridge not cold enough, advice needed (Refrigerator & Freezer Repair)
by AcuraNC 13 years ago
