I have replaced the control board ( it had a bad spot on it),the evaporator fan motor and thrermister, checked other two thermisters got about 6.5K value dropping as i held it.I also checked defrost and cleaned coils. How do I check the damper?
Hss25ifmdww hot point fridge Originally Posted by: PURCHIARONI@ATT.NET  I have replaced the control board ( it had a bad spot on it),the evaporator fan motor and thrermister, checked other two thermisters got about 6.5K value dropping as i held it.I also checked defrost and cleaned coils. How do I check the damper? As a follow up I removed air dampner and fridge is cold again . I would like to know how to test to see if it is getting proper voltage to it or what resistance the dampner should have
A make and model number may help others help you. |
THIS FORUM IS DEAD!!!!!!! |
This unit Is a hotpoint hss25ifmdww
