PURCHIARONI@ATT.NET
#1 Posted : Saturday, March 7, 2015 12:27:16 PM(UTC)
PURCHIARONI@ATT.NET
I have replaced the control board ( it had a bad spot on it),the evaporator fan motor and thrermister, checked other two thermisters got about 6.5K value dropping as i held it.I also checked defrost and cleaned coils. How do I check the damper?
PURCHIARONI@ATT.NET
#2 Posted : Sunday, March 8, 2015 4:48:18 PM(UTC)
PURCHIARONI@ATT.NET
Hss25ifmdww hot point fridge
As a follow up I removed air dampner and fridge is cold again . I would like to know how to test to see if it is getting proper voltage to it or what resistance the dampner should have
#3 Posted : Wednesday, March 11, 2015 2:05:27 AM(UTC)
A make and model number may help others help you.
PURCHIARONI@ATT.NET
#4 Posted : Wednesday, March 11, 2015 6:27:04 AM(UTC)
PURCHIARONI@ATT.NET
This unit Is a hotpoint hss25ifmdww
