kungfu10
#1 Posted : Thursday, July 24, 2014 7:06:27 PM(UTC)
kungfu10
My dryer stopped getting hot. I've never worked on before but decided to try for once. I tested for continuity....the thermal fuse, thermostat, & heating element. All tested good. It was purchased new approx. 3 years ago.
Kenmore 11060022010
My neighbor is an electrician & helped but we could not figure out.
What part should I focus on/buy first? What usually goes out first?
Thanks,
John
#2 Posted : Friday, July 25, 2014 1:53:39 AM(UTC)
Parts for Kenmore Dryer 11060022010 - AppliancePartsPros.com
See the attachment for the wiring diagram.
First check that you have 240 volts (L1 to L2).
Turn the unit on in timed dry.
Does the timer advance?
It also uses 240 volts.
If yes then you know that there is 240 volts and that the centrifugal switch (1M to 2M) is closing.
Unplug the unit and attach one meter lead to the L1 prong on the line cord and leave it there.
Set your meter on the most sensitive resistance scale.
It is a good idea to short the meter leads together before starting so you can see if there is a 0 offset in the meter.
Now work you way back through the heater circuit.
So C at the timer should be 0 ohms.
B and A at the timer should be 0 ohms.
Both sides of the thermal cutoff, the operating thermostat, the hi-limit thermostat and one side of the heating element should all be 0 ohms.
The other side of the heating element should be around 8 to 12 ohms.
File Attachment(s):
60022010.pdf (139kb) downloaded 14 time(s).
kungfu10
#3 Posted : Monday, July 28, 2014 10:43:21 AM(UTC)
kungfu10
Denman,
Thanks for your time & help. I printed the info out and will give it a shot. I will let you know the outcome.
John
kungfu10
#4 Posted : Monday, July 28, 2014 4:03:10 PM(UTC)
kungfu10
B does not ring out in off position.
It does in cycle.
9.5 at heating element
A does not ring out at all.
#5 Posted : Tuesday, July 29, 2014 12:53:17 AM(UTC)
Looks like the timer is shot.
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
