The ice dispenser stopped working. The water dispenser still worked. I removed the dispenser unit and checked the motor. It worked fine with current directly to it. I reinstalled the motor and ordered a new dispenser control panel. Installed it. Now the freezer light does not come on when the freezer door is opened but the dispenser motor turns on as soon as the door is opened. I haven't been able to find a legible wiring diagram to ensure that I haven't incorrectly installed the wires to the dispenser motor etc. Any ideas, including a legible wiring diagram would be greatly appreciated. Thanks
