Current Status:
LED light double blinks when door is open. Solid when LED door is closed and beam is unlocked. :) No frozen water in line. Check by fishing a flexible wire about a foot into the tube from the tray fill.:)
Water dispenses fine from the door and ice bin dispenser works..:)
Based on this and reading other posts I ordered and installed a new ice-maker. Installed the ice-maker and nothing.:confused:
I then did the jumper between the N and V test points. Nothing.:(
Jumpered between H and T. Nothing.:mad:
Now what?:confused:
bump
Now what?:confused: An inquiring mind wants to know
bump thread to top
Still looking for help before wife shoots me. :eek:
If no voltage between pins L and N on the modular icemaker, remove the receiver pc board and put a wire jumper between the black and black/ white wires. If you now get voltage to the icemaker, you have bad optics boards. Order them on this site.
Originally Posted by: richappy  If no voltage between pins L and N on the modular icemaker, remove the receiver pc board and put a wire jumper between the black and black/ white wires. If you now get voltage to the icemaker, you have bad optics boards. Order them on this site. is this the same as the Ice Level Power Control Board? Whirlpool 4389102 Ice Level Power Control Board Kit - AppliancePartsPros.comif so is this on the right or left?
Yes, the large, upper board is the receiver board, on the right side of the freezer. Just remove the receiver board and stick the jumper in the connector.
