rondegenaro
#1 Posted : Wednesday, July 9, 2014 10:15:47 AM(UTC)
rondegenaro
I set the temp to 350 and press start. After an hour the tempo has only reached 145. If I change to broil I can get the temp up to 350 and then change to bake. Is the bottom element bad and needs replacing or is there a problem with the temp gauge?
ebo2112
#2 Posted : Wednesday, July 9, 2014 11:36:26 AM(UTC)
ebo2112
I would access the bottom element, disconect it and test with ohm-meter (multi-meter).
You are hoping for zero (or very low) resistance across the contacts you just unplugged - resistance is measured in ohms (greek letter omega).
If resistance is very high or infinite , the element is burnt out.
Seems the logical place to start.
#3 Posted : Thursday, July 10, 2014 12:38:52 AM(UTC)
Does the unit stay in preheat?
If yes then odds are that the oven sensor is OK.
If the unit shows it is ready then it is probably a control problem.
A model number would be helpful.
If you check the bake (lower) element be sure to unplug the unit when doing this.
Many units have one side of the element always hooked to power so they must be unplugged or the breakers shut off.
Unplugging is the safer of the two.
Samsung oven temp low limit not switching back on (Oven Repair (including Ranges and Cooktops))
by amriths 2/25/2024 9:26:15 AM(UTC)
GE Cafe Dual Range - Oven Temp not matching display (Oven Repair (including Ranges and Cooktops))
by dieselgg 10/24/2023 3:22:11 PM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Thermador oven temperature fluctuates (Oven Repair (including Ranges and Cooktops))
by tylert 7/4/2022 1:19:07 PM(UTC)
Whirlpool RBS305PDB1 wall oven temp control (Oven Repair (including Ranges and Cooktops))
by WPoven 3/28/2022 7:14:02 PM(UTC)
Oven Temperature Regulation (Oven Repair (including Ranges and Cooktops))
by Tumbleweed_2 1/27/2022 9:20:22 PM(UTC)
JDS1750FS oven not reaching oven temperarture (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2021 1:06:18 PM(UTC)
Oven temp reading fluctuations if I turn oven up in temp or off and back on.... (Oven Repair (including Ranges and Cooktops))
by lorraineg57 11/19/2020 10:44:32 AM(UTC)
Wolf Dual Fuel DF366 oven temp regulation (Oven Repair (including Ranges and Cooktops))
by illfixanything 9/7/2020 6:49:58 PM(UTC)
Whirlpool oven temp too hot (Oven Repair (including Ranges and Cooktops))
by edorrian10 10/4/2017 1:18:52 PM(UTC)
Jenn-Air dual wall oven temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by jgmtfia 8/8/2017 1:20:49 AM(UTC)
Jenn-Air Oven Temperature Problems (Oven Repair (including Ranges and Cooktops))
by AndyBonner 9/3/2016 8:29:21 AM(UTC)
Whirlpool oven -long time to reach oven temp. (Oven Repair (including Ranges and Cooktops))
by Violet 1/23/2016 11:59:46 AM(UTC)
Kenmore oven temp troubleshooting (Oven Repair (including Ranges and Cooktops))
by Slinger 11/28/2015 4:42:29 PM(UTC)
