edorrian10
#1 Posted : Wednesday, October 4, 2017 1:18:52 PM(UTC)
edorrian10
Occasionally my oven temp will shoot up to over 500 degrees, no matter the temperature setting. For example, I set the oven to bake @ 350 degrees. The oven heats to over 550 degrees, based on the hanging thermometer in the oven. I have burnt several cakes this way. Why is the temperature skyrocketing? Do I need a new thermostat? control board?
ThatGuy
#2 Posted : Wednesday, October 4, 2017 6:49:30 PM(UTC)
ThatGuy
Groups: Expert
United States
Sounds like a relay on the board is getting stuck on. Most likely the bake relay is the problem.
edorrian10
#3 Posted : Friday, October 6, 2017 1:44:17 PM(UTC)
edorrian10
What part would I need to fix the bake relay on the board?
ThatGuy
#4 Posted : Friday, October 6, 2017 1:58:37 PM(UTC)
ThatGuy
Groups: Expert
United States
