Occasionally my oven temp will shoot up to over 500 degrees, no matter the temperature setting. For example, I set the oven to bake @ 350 degrees. The oven heats to over 550 degrees, based on the hanging thermometer in the oven. I have burnt several cakes this way. Why is the temperature skyrocketing? Do I need a new thermostat? control board?
Groups: Expert
Sounds like a relay on the board is getting stuck on. Most likely the bake relay is the problem.
What part would I need to fix the bake relay on the board?
Groups: Expert
