crabbygardener
#1 Posted : 11 years ago
crabbygardener
I've reviewed a few other post on GE dishwashers. I pulled the low spray arm off which does provide more water pressure, but the washer still does not drain. Ideas?
crabbygardener
#2 Posted : 11 years ago
crabbygardener
I took of the lower spray arm by pulling up and turning counter clockwise. I also took off the lower spray arm to the upper basket with 1/4 ratchet wrench. Drain the water with a carpet shampooer hand wand/ shop vac or baster. After that I went back to the parts by the mesh bottom. I pulled of part numbers 507 and 454 as both pieces had extreme scaling from hard well water. see link 05-Motor-Pump Mechanism parts for GE GDWT260R10SS - AppliancePartsPros.com
Then I pulled the grid basket towards the back that isn't that big. This crevice is where the food piled up. I pulled all particles with a baster out of this piece. I then put baking soda and vinegar down this piece since that's a natural drain cleaner. I let it fuzz up for 2 minutes. Then I added another 2 cups vinegar and 4 tbsp lemon juice to run in the cycle to get rid of the hard water scaling. Ran it on a Sani- wash cycle which was draining properly. I then reassembled the parts and ran a light cycle. Everything turned out and I got rid of the scaling. I will be running more vinegar and lemon washes to prevent this next round.
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 7 years ago
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 10 years ago
GE Dishwasher won't drain (Dishwasher Repair)
by mistercoffee1 11 years ago
GE dishwasher won't drain (Dishwasher Repair)
by Junebugatl 12 years ago
by Annie G 12 years ago
by brianlevenstein 12 years ago
by ann123 12 years ago
GE dishwasher won't drain completely (Dishwasher Repair)
by knight9995 13 years ago
by thuybrad 13 years ago
GE Dishwasher Won't Drain (Washer Repair)
by Jennifer216 13 years ago
GE Dishwasher Won't Drain Completely (Dishwasher Repair)
by ldubrowski 13 years ago
by deaconden 14 years ago
GE dishwasher won't drain, not plugged up (Dishwasher Repair)
by BonnieF 14 years ago
by renewer 14 years ago
by Bart1110 14 years ago
