Jennifer216
#1 Posted : Saturday, November 5, 2011 5:34:51 PM(UTC)
Jennifer216
I have a GE Dishwasher Model GLD5600. The dishwasher is 3 years old, and up until now, I have never had any problems with it. This week, it decided it no longer wants to drain. I read the owners manual, and the only suggestion was to run the garbage disposal to clear it of any debris. I did this, but the disposal was already empty, so this did not help. I also removed the sprayer arm (?) to see if anything was clogged under there. I was afraid to try to remove anything else and risk breaking a part that was fine to begin with. Any other suggestions for what I can do to find out what's causing the problem?
sidfink43
#2 Posted : Monday, November 7, 2011 5:02:05 PM(UTC)
sidfink43
You have posted on the clothes washer section. If you will re-post on the dishwasher forum someone should be able to help you.
The most likely problem is that some food particle is stuck in the drain hose or in the pump, or that the pump is not working.
Jennifer216
#3 Posted : Tuesday, November 8, 2011 1:39:53 PM(UTC)
Jennifer216
Okay I reposted in the proper section. Thanks!
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
by mistercoffee1 1/6/2014 8:57:53 PM(UTC)
GE dishwasher won't drain (Dishwasher Repair)
by Junebugatl 1/30/2013 9:42:45 AM(UTC)
by Annie G 12/14/2012 8:37:01 AM(UTC)
by brianlevenstein 12/11/2012 3:37:59 PM(UTC)
by ann123 12/9/2012 11:30:27 AM(UTC)
GE dishwasher won't drain completely (Dishwasher Repair)
by knight9995 10/5/2012 6:12:47 AM(UTC)
by thuybrad 11/8/2011 5:26:07 PM(UTC)
GE Dishwasher Won't Drain Completely (Dishwasher Repair)
by ldubrowski 11/4/2011 7:11:02 AM(UTC)
by deaconden 9/28/2011 7:23:00 AM(UTC)
GE dishwasher won't drain, not plugged up (Dishwasher Repair)
by BonnieF 9/16/2011 11:02:39 AM(UTC)
by renewer 8/6/2011 7:51:47 AM(UTC)
by Bart1110 11/3/2010 11:35:52 AM(UTC)
