Jennifer216
#1 Posted : 13 years ago
Jennifer216
I have a GE Dishwasher Model GLD5600. The dishwasher is 3 years old, and up until now, I have never had any problems with it. This week, it decided it no longer wants to drain. I read the owners manual, and the only suggestion was to run the garbage disposal to clear it of any debris. I did this, but the disposal was already empty, so this did not help. I also removed the sprayer arm (?) to see if anything was clogged under there. I was afraid to try to remove anything else and risk breaking a part that was fine to begin with. Any other suggestions for what I can do to find out what's causing the problem?
sidfink43
#2 Posted : 13 years ago
sidfink43
You have posted on the clothes washer section. If you will re-post on the dishwasher forum someone should be able to help you.
The most likely problem is that some food particle is stuck in the drain hose or in the pump, or that the pump is not working.
Jennifer216
#3 Posted : 13 years ago
Jennifer216
Okay I reposted in the proper section. Thanks!
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 7 years ago
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 10 years ago
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 11 years ago
by mistercoffee1 11 years ago
GE dishwasher won't drain (Dishwasher Repair)
by Junebugatl 12 years ago
by Annie G 12 years ago
by brianlevenstein 12 years ago
by ann123 12 years ago
GE dishwasher won't drain completely (Dishwasher Repair)
by knight9995 12 years ago
by thuybrad 13 years ago
GE Dishwasher Won't Drain Completely (Dishwasher Repair)
by ldubrowski 13 years ago
by deaconden 13 years ago
GE dishwasher won't drain, not plugged up (Dishwasher Repair)
by BonnieF 13 years ago
by renewer 14 years ago
by Bart1110 14 years ago
