crabbygardener
#1 Posted : Tuesday, June 10, 2014 6:30:07 PM(UTC)
crabbygardener
I've reviewed a few other post on GE dishwashers. I pulled the low spray arm off which does provide more water pressure, but the washer still does not drain. Ideas?
crabbygardener
#2 Posted : Wednesday, June 11, 2014 5:38:32 AM(UTC)
crabbygardener
I took of the lower spray arm by pulling up and turning counter clockwise. I also took off the lower spray arm to the upper basket with 1/4 ratchet wrench. Drain the water with a carpet shampooer hand wand/ shop vac or baster. After that I went back to the parts by the mesh bottom. I pulled of part numbers 507 and 454 as both pieces had extreme scaling from hard well water. see link 05-Motor-Pump Mechanism parts for GE GDWT260R10SS - AppliancePartsPros.com
Then I pulled the grid basket towards the back that isn't that big. This crevice is where the food piled up. I pulled all particles with a baster out of this piece. I then put baking soda and vinegar down this piece since that's a natural drain cleaner. I let it fuzz up for 2 minutes. Then I added another 2 cups vinegar and 4 tbsp lemon juice to run in the cycle to get rid of the hard water scaling. Ran it on a Sani- wash cycle which was draining properly. I then reassembled the parts and ran a light cycle. Everything turned out and I got rid of the scaling. I will be running more vinegar and lemon washes to prevent this next round.
Guest (4)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by mistercoffee1 1/6/2014 8:57:53 PM(UTC)
GE dishwasher won't drain (Dishwasher Repair)
by Junebugatl 1/30/2013 9:42:45 AM(UTC)
by Annie G 12/14/2012 8:37:01 AM(UTC)
by brianlevenstein 12/11/2012 3:37:59 PM(UTC)
by ann123 12/9/2012 11:30:27 AM(UTC)
GE dishwasher won't drain completely (Dishwasher Repair)
by knight9995 10/5/2012 6:12:47 AM(UTC)
by thuybrad 11/8/2011 5:26:07 PM(UTC)
GE Dishwasher Won't Drain (Washer Repair)
by Jennifer216 11/5/2011 5:34:51 PM(UTC)
GE Dishwasher Won't Drain Completely (Dishwasher Repair)
by ldubrowski 11/4/2011 7:11:02 AM(UTC)
by deaconden 9/28/2011 7:23:00 AM(UTC)
GE dishwasher won't drain, not plugged up (Dishwasher Repair)
by BonnieF 9/16/2011 11:02:39 AM(UTC)
by renewer 8/6/2011 7:51:47 AM(UTC)
by Bart1110 11/3/2010 11:35:52 AM(UTC)
