ag86IL
#1 Posted : Thursday, October 22, 2009 4:09:11 AM(UTC)
ag86IL
A few weeks ago the fridge started getting too warm then a few days ago the freezer did the same and yesterday they both went to 60 degrees. I inputed my model # into search but am not getting a breakdown diagram. Any input would be appreciated, the fridge guy is supposed to be here at 2:00, but if I could fix that would be better.
#2 Posted : Thursday, October 22, 2009 6:02:40 AM(UTC)
Here is the tech sheet.
http://manuals.frigidaire.com/p...f/Anderson/240389610.pdf
Sounds like it could be a defrost problem.
Remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is probably a defrost problem.
Could be the adaptive defrost board, the defrost heater or the defrost thermostat.
Try forcing a defrost cycle (see the tech sheet), if it defrosts then it is probably the board that is shot. Be careful do not burn your fingers.
If not it could be one of the other components.
Note the above test does not totally rule out that the board is OK.
Here are a couple good sites with additional fridge repair help
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
ag86IL
#3 Posted : Thursday, October 22, 2009 7:54:04 AM(UTC)
ag86IL
Thank you for the fast response. The fridge has been off since yesterday, I plugged it in and am not getting cold air. I forced the defrost and it makes the urrr noise that it did when it stopped cooling. So now I need to find the defrost things and test it.
ag86IL
#4 Posted : Thursday, October 22, 2009 8:29:45 AM(UTC)
ag86IL
The defrost heater tested at 000 ohms same with sensor. So is there a way to test defrost control or is this a replace item?
ag86IL
#5 Posted : Thursday, October 22, 2009 8:39:01 AM(UTC)
ag86IL
Forcing the defrost does not make the defrost heater change temp, I seem to be confusing myself more and more.
#6 Posted : Thursday, October 22, 2009 9:17:08 AM(UTC)
Might be best to wait for the repair person as you seem to be under the gun and this is not something you want to rush.
ag86IL
#7 Posted : Thursday, October 22, 2009 3:43:44 PM(UTC)
ag86IL
Guy said it was compressor, doesn't seem like a 6 year old fridge should crap out like that. Thanks for links though.
#8 Posted : Thursday, October 22, 2009 4:00:55 PM(UTC)
Used to be the sealed system (compressor, etc) had anywhere from 10 to 20 year warranties but the manufactures decided this was too long so now it is normally 5 years.
The change was definitely not made because compressors are more reliable.
Samsung Fridge and freezer incorrect temps (Refrigerator & Freezer Repair)
by Guest 4/3/2024 9:24:02 AM(UTC)
fridge and freezer repair (Refrigerator & Freezer Repair)
by Guest 6/21/2023 5:30:55 AM(UTC)
Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by DannyC77 4/26/2020 8:55:35 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Maytag Fridge PTW1949GRW hot to the touch between fridge and freezer (Refrigerator & Freezer Repair)
by mbarone 2/14/2019 6:08:20 AM(UTC)
Fridge and Freezer door sag (Refrigerator & Freezer Repair)
by WLHuard 7/11/2018 11:56:20 AM(UTC)
Both Fridge and Freezer running above setpoint... (Refrigerator & Freezer Repair)
by slider78 7/4/2017 9:18:48 PM(UTC)
Fridge and Freezer needs to be turned off and turned back on (Refrigerator & Freezer Repair)
by MaxieCode 6/10/2017 10:29:19 PM(UTC)
Fridge and freezer not cooling (Refrigerator & Freezer Repair)
by tommydoggett 4/6/2017 9:39:13 AM(UTC)
Fridge and freezer stopped cooling (Refrigerator & Freezer Repair)
by revg 8/12/2016 11:34:53 AM(UTC)
Fridge and freezer sections same temp (Warm) (Refrigerator & Freezer Repair)
by RichWard 8/1/2016 8:56:23 AM(UTC)
Fridge and freezer too warm, fans and compresser run constantly (Refrigerator & Freezer Repair)
by klide 6/14/2016 7:18:50 AM(UTC)
Fridge and freezer not cooling temp for both flashing 0 (Refrigerator & Freezer Repair)
by Biggie121 1/25/2016 11:10:41 AM(UTC)
Fridge and Freezer Intermittently Warm (Refrigerator & Freezer Repair)
by AnionicStrength 1/18/2016 4:03:08 PM(UTC)
Fridge and Freezer too warm (Refrigerator & Freezer Repair)
by collinsklein 12/28/2015 7:53:03 AM(UTC)
