2 Pages12>
#1 Posted : 17 years ago
You've done everything possible with the heating parts.
The first failure suspect in the line is the selector switch. Choose the "regular" cycle and check for continuity across the terminals 1 & 2, 3 & 4 and 5 & 6. All circuits should be closed.
If anyone is open - replace the selector switch.
If there is nothing wrong - replace the timer.
- The part number for the selector switch is AP2804338
- The part number for the timer is AP2804275
Here are the break down diagrams and the wiring schematic for the Bosch dishwasher Model SHU4002 UC/06
#2 Posted : 17 years ago
No doubt the selector switch caused the problem. It has to be replaced.
#3 Posted : 17 years ago
I'm glad you were able to fix it.
tmorin
#4 Posted : 17 years ago
tmorin
Hi Gene
I've been troubleshooting a similar Problem as OrvD. Timer gets stuck. I short the temp sensor on the front door and the cycle completes. We only use the Power Scrub cycle. I just replaced the temp sensor on the bottom near the heater too see if that was the culprit, I replaced the temp sensor on front and the cycle didn't complete. Heater ohms out to about 11 ohms.
I measure the following with the connector attached to the control board
sw 1-2 , 3-4, 5-6
Reg C , C, C
Del O, C, C
Rinse C, O, O
Scrub C, O, C
And with the connector disconnected :
sw 1-2 , 3-4, 5-6
Reg C , O, C
Del O, C, C
Rinse C, O, O
Scrub C, O, C
All are the same except for Reg cycle which we don't use. Is C, O, C correct for the power scrub cycle?
Tim
#5 Posted : 17 years ago
Hi Tim,
What is the complete model number of the dishwasher?
tmorin
#6 Posted : 17 years ago
tmorin
Shu 4006uc/u06
On another note. How long should a dishwasher last? Any preference for brands? Our #1 requirement is reliability and then low noise.
#7 Posted : 17 years ago
Hi Tim,
The push button switch is not good due to the testing results you posted: C, O, C for "regular" is wrong. It's hard to say what else could be wrong because of the age of the dishwasher and lack of technical documentation for such an old model.
I believe Bosch is a very good dishwasher. It is very silent and is designed very professionally.
Reliability today is not like it used to be 15-20 years ago on everything. If you decided to buy a new dishwasher, make sure you will get good manufacturer warranty and it could be a good idea to buy an extended warranty (if it's reasonably priced).
Here are the break down diagrams for the Bosch dishwasher Model SHU4006 UC/06
tmorin
#8 Posted : 17 years ago
tmorin
Thanks a bunch Gene
I'll post a reply when the switch comes in.
Tim
gblotter
#9 Posted : 14 years ago
gblotter
Many thanks to OrvD and Gene for the valuable info in this thread.
I have a Bosch SHU3012UC/U06 with the same problem (dial sticks at 5:00 and 9:00).
I have tested the continuity of the selector switch for each cycle (with the harness disconnected).
Closed = Continuity
Open = No Continuity
Results as follows:
CYCLE 1/2 3/4 5/6
Scrub C O O
Regular O C O
Rinse C O O
For my model of Bosch dishwasher, is this considered normal or do I have a bad selector switch that needs to be replaced?
2 Pages12>
