2 Pages12>
#1 Posted : Tuesday, February 12, 2008 6:37:51 PM(UTC)
You've done everything possible with the heating parts.
The first failure suspect in the line is the selector switch. Choose the "regular" cycle and check for continuity across the terminals 1 & 2, 3 & 4 and 5 & 6. All circuits should be closed.
If anyone is open - replace the selector switch.
If there is nothing wrong - replace the timer.
- The part number for the selector switch is AP2804338
- The part number for the timer is AP2804275
Here are the break down diagrams and the wiring schematic for the Bosch dishwasher Model SHU4002 UC/06
#2 Posted : Thursday, February 14, 2008 11:43:34 AM(UTC)
No doubt the selector switch caused the problem. It has to be replaced.
#3 Posted : Saturday, March 15, 2008 9:24:53 PM(UTC)
I'm glad you were able to fix it.
tmorin
#4 Posted : Sunday, June 22, 2008 5:23:39 PM(UTC)
tmorin
Hi Gene
I've been troubleshooting a similar Problem as OrvD. Timer gets stuck. I short the temp sensor on the front door and the cycle completes. We only use the Power Scrub cycle. I just replaced the temp sensor on the bottom near the heater too see if that was the culprit, I replaced the temp sensor on front and the cycle didn't complete. Heater ohms out to about 11 ohms.
I measure the following with the connector attached to the control board
sw 1-2 , 3-4, 5-6
Reg C , C, C
Del O, C, C
Rinse C, O, O
Scrub C, O, C
And with the connector disconnected :
sw 1-2 , 3-4, 5-6
Reg C , O, C
Del O, C, C
Rinse C, O, O
Scrub C, O, C
All are the same except for Reg cycle which we don't use. Is C, O, C correct for the power scrub cycle?
Tim
#5 Posted : Monday, June 23, 2008 12:27:36 PM(UTC)
Hi Tim,
What is the complete model number of the dishwasher?
tmorin
#6 Posted : Monday, June 23, 2008 12:32:09 PM(UTC)
tmorin
Shu 4006uc/u06
On another note. How long should a dishwasher last? Any preference for brands? Our #1 requirement is reliability and then low noise.
#7 Posted : Monday, June 23, 2008 7:20:09 PM(UTC)
Hi Tim,
The push button switch is not good due to the testing results you posted: C, O, C for "regular" is wrong. It's hard to say what else could be wrong because of the age of the dishwasher and lack of technical documentation for such an old model.
I believe Bosch is a very good dishwasher. It is very silent and is designed very professionally.
Reliability today is not like it used to be 15-20 years ago on everything. If you decided to buy a new dishwasher, make sure you will get good manufacturer warranty and it could be a good idea to buy an extended warranty (if it's reasonably priced).
Here are the break down diagrams for the Bosch dishwasher Model SHU4006 UC/06
tmorin
#8 Posted : Tuesday, June 24, 2008 4:40:46 AM(UTC)
tmorin
Thanks a bunch Gene
I'll post a reply when the switch comes in.
Tim
gblotter
#9 Posted : Thursday, July 7, 2011 6:41:40 AM(UTC)
gblotter
Many thanks to OrvD and Gene for the valuable info in this thread.
I have a Bosch SHU3012UC/U06 with the same problem (dial sticks at 5:00 and 9:00).
I have tested the continuity of the selector switch for each cycle (with the harness disconnected).
Closed = Continuity
Open = No Continuity
Results as follows:
CYCLE 1/2 3/4 5/6
Scrub C O O
Regular O C O
Rinse C O O
For my model of Bosch dishwasher, is this considered normal or do I have a bad selector switch that needs to be replaced?
2 Pages12>
