KSUMMER
#1 Posted : Tuesday, April 15, 2014 2:02:49 PM(UTC)
KSUMMER
Bake element completely broke, I have replaced but it still will not work. Broil and stove top still work fine. I know the new element works, are there any fuses?
#2 Posted : Wednesday, April 16, 2014 3:35:13 AM(UTC)
Parts for Admiral LER3330AAW Range - AppliancePartsPros.com
There are no fuses.
Sounds like when the element blew it also blew the control board (item7 in section 02)
File Attachment(s):
LER3330.pdf (213kb) downloaded 0 time(s).
OEM or Aftermarket Replacement Bake Element? (Oven Repair (including Ranges and Cooktops))
by lbb78 4/18/2024 10:05:55 AM(UTC)
Bake Element Debris? (Oven Repair (including Ranges and Cooktops))
by Dan0tn 1/23/2024 9:18:53 AM(UTC)
GE oven bake element (Oven Repair (including Ranges and Cooktops))
by 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Using a Broiler element to replace a bad Bake Element (Oven Repair (including Ranges and Cooktops))
by Guest 11/22/2021 2:49:19 PM(UTC)
Frigidaire FGEW3065PDF bake element (Oven Repair (including Ranges and Cooktops))
by crowsons 10/30/2021 3:22:26 PM(UTC)
Hidden bake element whirlpool range (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2021 10:05:04 AM(UTC)
Modern Maid bake Element Replacement (Oven Repair (including Ranges and Cooktops))
by Gkvaas 4/22/2020 4:00:01 PM(UTC)
Viking Bake Element (Oven Repair (including Ranges and Cooktops))
by djb16 2/23/2020 7:28:49 AM(UTC)
Kenmore Electric Wall Oven 790.41003603 - Broil AND Bake elements won't heat (Oven Repair (including Ranges and Cooktops))
by acehigh21 7/28/2019 11:14:25 AM(UTC)
Kitchenaid Bake Element Problem (Oven Repair (including Ranges and Cooktops))
by mawaw 3/2/2019 10:12:44 AM(UTC)
Replace bake element on electric range/oven (Oven Repair (including Ranges and Cooktops))
by bad Dog 2/24/2019 9:17:21 AM(UTC)
How to replace hidden bake element in GE JKP30SM1SS (Oven Repair (including Ranges and Cooktops))
by scarpenter444 9/6/2018 5:01:15 AM(UTC)
Bake element on Wall Oven (Oven Repair (including Ranges and Cooktops))
by Enore 3/4/2018 11:26:13 AM(UTC)
Bake element not receiving power (Oven Repair (including Ranges and Cooktops))
by tiredoftakeout 3/11/2017 3:03:02 PM(UTC)
