herman
#1 Posted : Monday, February 11, 2008 3:01:40 PM(UTC)
herman
When I push the start , nothing.where should I start, besides the door swich.
thank you herman:confused:
#2 Posted : Tuesday, February 12, 2008 12:32:30 PM(UTC)
The first thing I would check is 120V at the power outlet and proper plug connection.
If there is nothing wrong, remove the bottom panel and check for burned wires at the junction box.
If this is not the issue then check the door switches and all wires.
The last step is to replace the control board.
- The part number for the control board is AP3875193
herman
#3 Posted : Wednesday, March 12, 2008 12:57:41 PM(UTC)
herman
I've checked power , door switches. I alsohave tried the field test that was with the unit for testing the componets, but I can't even get that to work. I know i'm missing something.I just didn't want to order the circuit board till I was sure. any help would be appreaciated.
thank you dave lynch
( Herman)
amna adb1200aws
#4 Posted : Wednesday, March 12, 2008 1:07:48 PM(UTC)
If you have 120V across both door switches then the problem is a bad control board.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Washer cycle won't start, motor just buzzes (Washer Repair)
by Guest 4/6/2023 4:46:53 PM(UTC)
Samsung DV42H5200EW/A3 Dryer makes loud buzzing noise and won't start unless (Dryer Repair)
by bvon 4/3/2023 9:46:22 PM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Samsung washing machine won't start (Washer Repair)
by Guest 11/14/2022 7:56:18 AM(UTC)
Maytag MDBH985AWS Won't Start Motor Humming (Dishwasher Repair)
by pdmac00 10/11/2022 12:48:23 PM(UTC)
Whirlpool WTW7500gc0 has power but won't start (Washer Repair)
by Guest 2/27/2022 2:52:51 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
dryer WED8300swo won't start (Dryer Repair)
by Guest 10/26/2021 10:24:13 AM(UTC)
Maytag LAT9600AAW Won't Start (Washer Repair)
by Guest 8/28/2021 6:11:33 AM(UTC)
