timwhitten
#1 Posted : Monday, March 24, 2014 2:15:09 PM(UTC)
timwhitten
The dishwasher worked great until just recently. All of the buttons on the control panel illuminate properly except the start button. It blinks ... I push the button and it quits blinking and stays on only for a few seconds... then begins blinking again. The dishwasher never engages during the process.
Any ideas? I appreciate the help.
#2 Posted : Wednesday, March 26, 2014 2:39:12 AM(UTC)
Parts for Maytag MDB7709AWQ2 Dishwasher - AppliancePartsPros.com
Below is a link to a data sheet
Download MDB7709.pdf
Unclick the use our down loader and then use the grey download button. Otherwise you may end up with software on your computer that you do not want.
I am assuming that you have already turned power off to the unit to see if it will reset.
As you can see a blinking light is often a shorted key.
Check the key outputs from the keypad with a meter, to see if it is OK.
If OK then I would replace the control board.
Still not a guaranteed to fix the problem but your odds are better.
Miss Mom
#3 Posted : Friday, April 11, 2014 2:30:34 PM(UTC)
Miss Mom
Same thing with my dishwasher. What ended up being your issue? I keep putting off calling a repairman thinking I can figure it out. TIA
timwhitten
#4 Posted : Wednesday, April 30, 2014 11:01:00 AM(UTC)
timwhitten
Sorry for the delay in responding, but a new control board fixed the issue. It was also very easy to replace, in case you were having any reservations about attempting the repair.
Miss Mom
#5 Posted : Wednesday, April 30, 2014 11:41:17 AM(UTC)
Miss Mom
Ours turned out to be a stuck button on the control panel. The guy told us he thought it could be two different things and neither were a cheap fix. He was going to start with one (around $150) and see if that worked and then go to the other (also about $150)....called the appliance parts place and luckily for me...they were out of both so he said he would try "one more thing" and it turned out to be a stuck button! So basically the whole thing ended up costing me a $75 service call on a Saturday. I felt pretty lucky! Thanks for your response!:)
Maytag dishwasher will not start (Dishwasher Repair)
by bryan ponder 4/1/2011 11:33:54 AM(UTC)
by lauranne 12/17/2010 7:40:45 PM(UTC)
Maytag Dishwasher will not start (Dishwasher Repair)
by mcr2343 11/23/2009 10:04:51 AM(UTC)
by jsievert 11/18/2009 7:30:06 PM(UTC)
