belliemom
#1 Posted : Friday, February 28, 2014 5:20:18 PM(UTC)
belliemom
Could you give me any helpful hints on installing a new ignitor for my oven. AKA what and how to do it myself in laymans terms... Thanks
festeraddams
#2 Posted : Friday, February 28, 2014 5:40:55 PM(UTC)
festeraddams
Pull the panel off (assuming bake) the bottom, detach the flame spreadder, take the couple screws holding the burner in out. Put a drop of oil on the threads on the back of the flange on the burner for the ignitor, unscrew ignitor, (if you got one with a plug unplug the old one, plug the new on in, if you have the CERAMIC wire nuts, cut the wires, strip and use the wirenuts) - all of this of course with the unit unplugged..... reverse process.....
Guest (4)
Kitchenaid Gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Travelguy 1/1/2014 5:52:03 PM(UTC)
Oven wont heat up (Oven Repair (including Ranges and Cooktops))
by shellyrodriguez 11/23/2013 8:55:12 AM(UTC)
Frigidaire Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by GHog 5/7/2013 3:18:52 PM(UTC)
ge wall oven wont heat up (Oven Repair (including Ranges and Cooktops))
by henson1166 1/5/2013 5:08:07 AM(UTC)
lights come on oven wont heat up (Oven Repair (including Ranges and Cooktops))
by fxe81hd 5/3/2012 12:43:28 PM(UTC)
by CLL 11/8/2011 9:11:49 AM(UTC)
whirlpool oven wont heat up (Oven Repair (including Ranges and Cooktops))
by tim hinson 5/11/2011 3:49:42 PM(UTC)
Thermador Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by DonD 10/17/2010 8:53:15 AM(UTC)
magic chef wall oven wont heat up.it ignites (Oven Repair (including Ranges and Cooktops))
by barbara1 9/10/2010 2:01:00 PM(UTC)
Oven wont heat up after locking the door (Oven Repair (including Ranges and Cooktops))
by kescrig 8/10/2010 10:42:33 AM(UTC)
by bigdaddy5 4/25/2010 2:10:48 PM(UTC)
maytag oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Dan-o 3/30/2010 12:17:15 AM(UTC)
by mamoody 6/16/2009 5:29:34 PM(UTC)
oven wont heat up by itself (Oven Repair (including Ranges and Cooktops))
by garhd 8/9/2008 11:42:29 AM(UTC)
Kenmore gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by searvle 8/4/2008 1:17:30 PM(UTC)
