eyemall
#1 Posted : Sunday, February 16, 2014 4:53:10 PM(UTC)
eyemall
My refrigerator is warm but the freezer side is freezing. The condenser coil is frozen up. I changed the defrost thermostat. It did not help. The condenser fan is running only in short bursts but sometimes will run for about a minute before returning to the short bursts. I tried another fan motor and it did the same thing. Would a bad defrost timer board cause this problem?
#2 Posted : Wednesday, February 19, 2014 2:58:02 AM(UTC)
A model number may help others help you.
I think you are getting the evaporator coil and fan mixed up with the condenser coil and fan.
The evaporator is in the freezer.
Yes it could be the defrost board if the unit uses one.
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Frigidaire Refrigerator, not cooling (Refrigerator & Freezer Repair)
by Guest 7/31/2022 11:09:46 AM(UTC)
Frigidaire Refrigerator Fan(s) Inside Cycling On And Off To Get Started (Refrigerator & Freezer Repair)
by JamesDIY 4/28/2022 1:25:48 AM(UTC)
Frigidaire Refrigerator GLHS268ZDS2 (Refrigerator & Freezer Repair)
by Pursue 10/26/2021 2:10:36 PM(UTC)
Frigidaire Refrigerator FFTR1814LW9 (Refrigerator & Freezer Repair)
by Guest 10/11/2021 9:30:20 AM(UTC)
Frigidaire refrigerator handle (Appliance Parts)
by Eastwezt 8/20/2021 10:04:25 AM(UTC)
2003 Frigidaire Refrigerator (Refrigerator & Freezer Repair)
by Guest 6/25/2021 5:52:53 PM(UTC)
Model FRS23H5ASB8 Frigidaire Refrigerator issue (Refrigerator & Freezer Repair)
by Johnnyvirgil 2/15/2021 9:20:33 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Frigidaire Refrigerator LGHT1846QP1 - door switch and cabinet cooling (Refrigerator & Freezer Repair)
by BJPrice 10/26/2020 5:28:12 AM(UTC)
Frigidaire refrigerator model # FRT18S6AW9 (Refrigerator & Freezer Repair)
by rlundin@nycap.rr.com 6/29/2020 4:32:36 PM(UTC)
Frigidaire Refrigerator FGHS2644KF1 (Refrigerator & Freezer Repair)
by Shutterbug962 5/23/2020 12:51:57 PM(UTC)
My Frigidaire Refrigerator stopped workin (Refrigerator & Freezer Repair)
by justme0987 4/8/2020 12:18:43 PM(UTC)
