tjholder04
#1 Posted : Wednesday, February 12, 2014 5:03:41 AM(UTC)
tjholder04
Last night my washer filled up with water, but when it came time to agitate, nothing happened. No sound is made. It is completely quite. The dial on the washer did not move through the cycle. I tried switching to multiple cycles to see if it will agitate and nothing happened. I don't hear the motor making a sound. It is not draining, spinning or agitating. I just replaced the lid switch.
Please provide feedback.
Thanks!
fairbank56
#2 Posted : Wednesday, February 12, 2014 6:55:17 AM(UTC)
fairbank56
Groups: Expert
Model number???
tjholder04
#3 Posted : Wednesday, February 12, 2014 8:25:22 AM(UTC)
tjholder04
fairbank56
#4 Posted : Wednesday, February 12, 2014 9:17:49 AM(UTC)
fairbank56
Groups: Expert
Remove the cabinet and check the motor wiring connector. Tug on all the wires there to see if any have broken inside the connector housing. Unplug the connector and check terminals for burning/corrosion. Do you have a multimeter for testing voltages and continuity? You can operate washer with cabinet off but will have to bypass the lid switch for drain/spin operation/testing.
Lid switch bypass: https://www.youtube.com/watch?v=XAnQ6Ovvnuc
Eric
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
