jamespat44
#1 Posted : Friday, February 7, 2014 4:24:32 PM(UTC)
jamespat44
My sister tried to change the bottom coil without unplugging the oven and it sparked. The oven now has no power and no lights.
She tried to turn the kitchen circuit breakers on and off but nothing worked.
Someone said that it may be the thermal fuse. I know in most of these ovens they have 2 internal fuses so I wanted to know what experts thought. Thanks so much.
P.S. smh about my sister.
GMBILL
#2 Posted : Saturday, February 8, 2014 9:41:10 AM(UTC)
GMBILL
Unless you have some electrical experience, this may be difficult. The first thing is to 'UNPLUG' the unit and see if the "direct short" she caused may have burned the wire or wirwes at or around the main supply. In order to do this, you must pull the stove out, remove the main supply cover and visually check the connections. If they seem to be alright, remove the back cover panel and trace the supplies of both 120v to the control unit.
Please be careful. MAKE SURE YOU UNPLUG YOUR STOVE BEFORE CHECKING ANY OF THIS. Hope this gets you started...GMBILL
jamespat44
#3 Posted : Saturday, February 8, 2014 10:11:37 AM(UTC)
jamespat44
thanks so much; I also heard that there is a circuit breaker so I want to try that too. thank you
#4 Posted : Sunday, February 9, 2014 1:48:40 AM(UTC)
Parts for GE JBP48WB4WW Range - AppliancePartsPros.com
I looked through them but cannot find a circuit breaker, thermal cut-off or a fuse perhaps you will have better luck.
FYI: It is not common for a stand alone range to have breakers etc.
Built in ovens have them as a fire protection.
kenmore dryer 79681029900 no power at all (Dryer Repair)
by jakethekid82 6/7/2019 2:24:53 PM(UTC)
No power at all (Oven Repair (including Ranges and Cooktops))
by KristyTabor 1/24/2016 9:00:34 AM(UTC)
dishwasher no power at all (Dishwasher Repair)
by drtrust 6/6/2013 10:38:00 AM(UTC)
Frigidaire LPHS2687KF1 has no power at all (Refrigerator & Freezer Repair)
by JRich87 3/9/2012 4:46:38 AM(UTC)
No power at all (Microwave Repair)
by HAEDO 3/23/2011 5:17:51 PM(UTC)
No Power at all (Microwave Repair)
by fun4all 10/25/2010 12:55:01 PM(UTC)
No power at all (Dryer Repair)
by jrex7 12/27/2009 9:54:00 AM(UTC)
No power at all on refrigerator (Refrigerator & Freezer Repair)
by aspivey@carolina.rr.com 9/28/2009 10:35:12 AM(UTC)
No Power At All (Dishwasher Repair)
by sweber11 5/21/2009 1:44:52 PM(UTC)
dryer shorted out- no power at all (Dryer Repair)
by rolmr 5/7/2009 11:17:42 AM(UTC)
