rolmr
#1 Posted : Thursday, May 7, 2009 11:17:42 AM(UTC)
rolmr
I recently moved the dryer into the basement, got it hooked up and all was good for a few seconds. Then I heard a something from the fuse box and the power in the dryer went out completely. Found out the ground wire was bare and exposed-- apparently it shorted (the copper was nice and black) but didn't trip the breaker.
Now nothing is working. Does anyone know if there is a fuse in this model or what i can try prior to calling a technician or what part I should test first?
#2 Posted : Thursday, May 7, 2009 2:09:38 PM(UTC)
Replacement parts for WHIRLPOOL WED9200SQ0 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...heet%20-%20W10110638.pdf
Since the unit is totally dead the electronic power supply is at the top of the possible causes.
rolmr
#3 Posted : Saturday, May 9, 2009 6:13:13 AM(UTC)
rolmr
i appreciate the tech sheet- they recommend replacing the machine control electronics- do you know if there is a way to test that part. Trial and error with electronics can get expensive.
#4 Posted : Sunday, May 10, 2009 2:47:31 AM(UTC)
If it is totally dead there are no automatic checks that can be run.
All you can do is check that that the board is receiving power with a meter.
If yes, then the control board is at the top of the list
rolmr
#5 Posted : Sunday, May 10, 2009 11:26:52 AM(UTC)
rolmr
Thanks for the help. Checked the power going into the board and it was fine. The replacement should be here next week- Hopefully it's the problem.
