Leaking from center of tub also making roaring noise took apart there is a large trunnion attached to inner tub removed all screws cant get trunnion loose from inner tub any knowledge or removal tool would be greatly appricated :confused:
I am not getting your model number to come up but it sounds like this is a basic Frigidaire top loader, so here is a link to the service manual. http://www.emaservicetips.com/pdfs/489_5.pdfMy concern is that water has leaked into the tranmission and that is causing your noise in which case you may want to consider replacing the unit.
It is a top load frigdare glass door no agitator model # FAHE4044MW0 The washer is desighned like the calypso i can find parts on the machine using that model # it is leaking and making a roaring noise and has a large trunnion secured to the inner tub i cannot remove i was looking for advice on removal of trunnion or if they make a removal tool
I am sorry but I am just not familiar with this model, hopefully someone else who responds on this site can help you.
