steelem@myomnitel.com
#1 Posted : Monday, February 3, 2014 10:20:19 AM(UTC)
Amana LWA20AW
fills with water, agitates but DOES NOT spin or drain.
motor hums with no movement
gave the belt a little help and it will agitate but not spin.
took front off and the belt moves freely in one direction and a little more resistance in the other direction.
I can here the door switch click when opening and shuting.
what next?
sidfink43
#2 Posted : Tuesday, February 4, 2014 3:31:07 PM(UTC)
sidfink43
If it starts up and runs after you turn the belt then the most likely problem is the motor, it has start windings and run windings and the start windings may not be working. It could also be the start switch.
Given the age of the machine and the cost of a motor I suggest you consider a replacement with a basic top loader.
washer wont spin or drain (Washer Repair)
by hunter02 7/15/2013 10:36:02 PM(UTC)
by dionnaorner 4/11/2013 5:27:51 PM(UTC)
Washer Wont Spin Or Drain (Washer Repair)
by tammy924 1/17/2013 10:11:49 AM(UTC)
dishwasher wont spin or drain (Dishwasher Repair)
by jbenn 6/4/2012 7:12:32 PM(UTC)
My washer wont spin or drain (Washer Repair)
by Elizabeth2323 4/5/2012 5:15:32 PM(UTC)
roper washer wont spin or drain water (Washer Repair)
by michalek 3/28/2011 6:59:22 PM(UTC)
by rday 11/1/2009 7:07:27 PM(UTC)
by jcreek 7/22/2008 8:00:15 AM(UTC)
