Currently using PG gas. The left front burner has a lot of yellow flame and causes a lot of soot on the bottom of the pans. The other 3 burners burn a nice blue and have no problem. Have taken the burner assemblies apart and cleaned them as advised by the LP gas dealer. But still this one burner is a problem. I have looked at replacement parts but they appear to no longer be available. Advice? One other item. I have had an ongoing problem with the igniter, the unit has been replace by GE repair but it never worked right. Just kept on clicking and did not ignite the burner even though I could see the spark.
THIS FORUM IS DEAD!!!!!!! |
