Sawman
#1 Posted : Sunday, February 2, 2014 10:10:53 AM(UTC)
Sawman
Currently using PG gas.
The left front burner has a lot of yellow flame and causes a lot of soot on the bottom of the pans. The other 3 burners burn a nice blue and have no problem. Have taken the burner assemblies apart and cleaned them as advised by the LP gas dealer. But still this one burner is a problem. I have looked at replacement parts but they appear to no longer be available.
Advice?
One other item. I have had an ongoing problem with the igniter, the unit has been replace by GE repair but it never worked right. Just kept on clicking and did not ignite the burner even though I could see the spark.
#2 Posted : Monday, February 3, 2014 2:11:18 AM(UTC)
Parts for JGP932BEC - AppliancePartsPros.com
Here is the install sheet
http://products.geapplia...&Name=31-10537-2.pdf
If this has always been a problem then there is a possibility that this burner was never converted to propane.
GE Gas Cooktop Ignitors stopped clicking (Oven Repair (including Ranges and Cooktops))
by StoveIdiot 4/24/2013 4:13:19 PM(UTC)
GE Gas Cooktop - No Ignitors Are Clicking (Oven Repair (including Ranges and Cooktops))
by JBiggs 2/11/2013 9:23:58 AM(UTC)
GE Gas Cooktop Ignitor Clicks Once Every 30-45 Minutes (Oven Repair (including Ranges and Cooktops))
by Wick 8/8/2012 11:03:45 AM(UTC)
GE Gas cooktop sparking constantly (Oven Repair (including Ranges and Cooktops))
by bear-dog 11/11/2011 2:48:07 PM(UTC)
GE gas cooktop (Oven Repair (including Ranges and Cooktops))
by Sabo Sabo 6/30/2011 6:35:38 AM(UTC)
ge gas cooktop one burner will not ignite (Oven Repair (including Ranges and Cooktops))
by 2cheap 1/25/2010 12:11:14 PM(UTC)
GE gas cooktop igniter keeps clicking (Oven Repair (including Ranges and Cooktops))
by Craig-o 11/20/2009 11:18:19 AM(UTC)
GE Gas Cooktop - Fan comes on by itself (Oven Repair (including Ranges and Cooktops))
by dilawari 7/1/2009 6:36:29 AM(UTC)
GE gas cooktop igniter probelm (Oven Repair (including Ranges and Cooktops))
by Manish 4/2/2008 2:15:44 PM(UTC)
GE gas cooktop igniter won't spark and lit (Oven Repair (including Ranges and Cooktops))
by ewe 3/3/2008 7:29:29 PM(UTC)
