Tracy Lynch
#1 Posted : Wednesday, January 29, 2014 1:30:21 PM(UTC)
Tracy Lynch
My dryer stopped heating. I changed thermal fuse and heating element and still have no heat. I did check continuity of heating element and had open line and found one of the coils came apart. everything I search for this problem says it should be one of these parts, but obviously not. could you please tell me what the problem could be?
fairbank56
#2 Posted : Wednesday, January 29, 2014 4:16:10 PM(UTC)
fairbank56
Groups: Expert
Does the timer advance when in timed dry function? If not, check that you have 240vac at dryer power cord connection block on back of dryer behind small panel. With dryer unplugged, make sure those connections are clean and tight and there is no burning/melting of wires or terminals there. If ok, problem could be timer, motor switch or a faulty connection in the heater circuit. You say you replaced the thermal fuse. The thermal fuse is in the motor circuit, motor would not run if it was bad. Are you talking about the thermal cutoff on the top of the heater box? Did you check continuity of the hi-limit thermostat at bottom of heater box?
Eric
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
