jeany
#1 Posted : Friday, October 16, 2009 12:59:46 PM(UTC)
jeany
water freezes on the bottom of the freezer and when it melts leaks through the bottom of door onto the floor. Any suggestions?
kooler
#2 Posted : Friday, October 16, 2009 4:31:35 PM(UTC)
kooler
Remove the bottom shelf/drawer in the freezer compartment and look at the back wall... You should be able to see a trough filled with ice that will need to be removed with a hair dryer to expose a drain hole that will need cleaning out also... There should be hose attached to this drain which carries condensate from the defrost cycle to the pan underneath the fridge.. Make sure this hose is clean also...
Magic Chef RV Parts (Appliance Parts)
by Jerry Funk 8/9/2022 1:54:09 PM(UTC)
Magic chef single wall unit (Oven Repair (including Ranges and Cooktops))
by Guest 11/13/2021 5:50:28 PM(UTC)
Magic Chef thermal fuse equivalent (Microwave Repair)
by bassclef78 10/13/2021 9:40:22 AM(UTC)
Magic Chef refrigerator lost its coldness (Refrigerator & Freezer Repair)
by Guest 5/3/2021 12:13:56 PM(UTC)
PTC Start Relay for Magic Chef wine/beer refrigerator (Refrigerator & Freezer Repair)
by dereknfoster 8/31/2020 12:46:08 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
magic chef can cool but wont (Refrigerator & Freezer Repair)
by jsuss01 8/6/2019 9:47:10 PM(UTC)
Magic Chef B 38HN 42TVW F4 then F2 error (Oven Repair (including Ranges and Cooktops))
by steviemcstevesteve 7/20/2019 10:37:10 AM(UTC)
Magic Chef Refrigerator and Freezer Warm Intermittenly (Refrigerator & Freezer Repair)
by delmar858 3/23/2019 11:20:27 AM(UTC)
Magic Chef Mini Fridge - I can't find parts or part numbers (Refrigerator & Freezer Repair)
by domwebhost 6/21/2017 12:31:28 PM(UTC)
16 year-old Magic Chef started making loud popping sounds (Refrigerator & Freezer Repair)
by webgrunt 2/13/2017 7:07:03 AM(UTC)
Magic Chef freezer not freezing. (Refrigerator & Freezer Repair)
by DavidESny 9/5/2016 7:07:37 PM(UTC)
Magic Chef Circuit Reset? (Oven Repair (including Ranges and Cooktops))
by TheBlackSwapper 1/18/2016 10:27:15 AM(UTC)
Magic Chef Heavy Duty Washer (Washer Repair)
by SandyMesman 4/28/2015 6:13:22 AM(UTC)
Magic Chef oven/broiler ignition problem (Oven Repair (including Ranges and Cooktops))
by steve_page@ymail.com 3/24/2015 7:07:54 AM(UTC)
