annetteogg
#1 Posted : Wednesday, January 8, 2014 8:20:02 AM(UTC)
annetteogg
Why does the washer barrel fill with water some time after a load is completed?
#2 Posted : Friday, January 10, 2014 2:12:03 AM(UTC)
Parts for Whirlpool GHW9400SU0 Washer - AppliancePartsPros.com
If I understand your post.
The unit washes OK and spins out the clothes OK but if you are not using the unit it fills with water over time.
If yes to the above then it could be that your water vale is leaking.
One way to check this is to unplug the unit. If it still fills with water replace the water valve.
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
LTF2940FE0 FRIGIDAIRE FRONT LOAD WASHER (Washer Repair)
by Guest 9/8/2022 9:06:55 PM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
fRIDGIDAIRE AFFINITY FRONT LOAD WASHER WILL NOT STAY IN LOCK MODE (Washer Repair)
by Guest 2/21/2022 3:21:13 PM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Samsung front load washer rotor cover hitting (Washer Repair)
by Kickerjb44 12/19/2021 3:31:57 PM(UTC)
Samsung Front Load Washer Gets Stuck at 1 Minute (Washer Repair)
by Radar314 11/12/2021 5:45:08 AM(UTC)
maytag 2000 front load washer (Washer Repair)
by crazyeyebrad 10/30/2021 7:34:44 AM(UTC)
WF56H9100AG/A2 Samsung Front Load Washer Displays 4e / LE error code (Washer Repair)
by dcgtechnologies 10/1/2021 9:38:54 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
