Why does the washer barrel fill with water some time after a load is completed?
Here are your parts Parts for Whirlpool GHW9400SU0 Washer - AppliancePartsPros.comIf I understand your post. The unit washes OK and spins out the clothes OK but if you are not using the unit it fills with water over time. If yes to the above then it could be that your water vale is leaking. One way to check this is to unplug the unit. If it still fills with water replace the water valve. |
THIS FORUM IS DEAD!!!!!!! |
