here in central pa.this morning it was -6 degrees.i have a trane heat pump w/ a 10kw heat strip. it struggled all day to keep it half decent in here. could I put a larger heat strip in & what benefit would it do?
thanks dave
Most likely you could add a bigger heat strip but most likely you would have to increase to a bigger wire feeding the air handler/heat strip. You almost need to talk to a Trane dealer to see what fits your system and what other sizes and wiring needs you would need for a heater.
Whirlpool heat pump dryers
(Dryer Repair)
by Aptmtncguy
1/19/2024 3:44:50 PM(UTC)
Rheem RQNJ-A048JK000 heat pump
(Heating, Ventilation, and Air Conditioning (HVAC))
by Guest
5/16/2023 7:10:38 AM(UTC)
Goodman heat pump very rapid cycling
by tkolarik
3/26/2011 10:21:35 AM(UTC)
Replace heat pump condnsr w' normal A/C condenser
by zjtr10
3/20/2011 11:03:25 AM(UTC)
Rheem Heat Pump Help
by bradford
3/3/2010 1:36:01 PM(UTC)
Old heat pump trowing breaker
by neverforget.911
5/25/2009 7:48:31 PM(UTC)
Whirlpool AC/Heat pump - no heat
by martydoug@gmail.com
11/4/2008 10:29:51 AM(UTC)
