We have a rent house with a 1992 Trane 2.5 ton heat pump system that has a bad compressor. I want to replace the heat pump conderser with a normal a/c condenser and leave the heat pump evap coil in place. Not taking into account the lose of effcientcy will this work? I'll use the electric heat strips for heat. Thanks.
Originally Posted by: glpgcotsv  浙商理财的22条军规1.保持瞅CCTV-1消息联播。  要想掌握经济命根子,必需关注政局,消息联播图文并茂,绘声绘色,着真为中国商人的最好晴雨表;你可以不看财经报路,也可以不看焦点访聊,假如你不是做石油和外汇的,甚至你都可以不往管相似9.11事件和中东局面。  2.不要轻易相信合约或合同  哪怕折约让你的律师看过了,私证处公证了都不要等闲信任,甚至当你的客户把钱已经汇进你指定的账户当前你都必须确认,这笔钱你能不能拿没来,能不能动,而合约以外quote]
Thank you very much for taking the time to explain this to me. The links you provided were very helpful. Now that I have a more through grasp of what needs to be done I will proceed. I am most grateful for your help.
