After cleaning the top oven it will no longer heat up. Bottom oven works fine. Control panel for top oven reads LO but no heat. Checked both thermal switches on the back for continuity, both check out fine. Any suggestions?
THIS FORUM IS DEAD!!!!!!! |
Denman, Thanks for the response. I have ordered the part. Will be more aware of the "hazards" involve with the cleaning cycle in the future. Dtlalonde
