dtlalonde
#1 Posted : Tuesday, January 7, 2014 8:55:22 AM(UTC)
dtlalonde
After cleaning the top oven it will no longer heat up. Bottom oven works fine. Control panel for top oven reads LO but no heat. Checked both thermal switches on the back for continuity, both check out fine. Any suggestions?
#2 Posted : Wednesday, January 8, 2014 2:34:15 AM(UTC)
Here are your parts.
Parts for Whirlpool KEBC206KBL04 Wall Oven - AppliancePartsPros.com
Since you have checked the thermal fuse for the upper oven elements and it is OK and the readout shows that the board knows that the temperature is low (oven sensor is OK) so should be heating.
I would say that the control board needs replacing.
dtlalonde
#3 Posted : Thursday, January 9, 2014 7:19:03 AM(UTC)
dtlalonde
Denman,
Thanks for the response. I have ordered the part. Will be more aware of the "hazards" involve with the cleaning cycle in the future.
Dtlalonde
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
Maytag Double OVen Model MGR6875ADW- Igniter wont stop ticking (Oven Repair (including Ranges and Cooktops))
by gnieciag 10/15/2023 1:53:42 PM(UTC)
Maytag MGR6875ADW Double Oven - Burner top (Oven Repair (including Ranges and Cooktops))
by gnieciag 8/29/2023 5:38:52 PM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
KitchenAid KEBC208KBT03 Superba Double Oven F5-E1 (Oven Repair (including Ranges and Cooktops))
by ericpeterson 1/9/2023 5:45:49 PM(UTC)
Jennair double oven (Oven Repair (including Ranges and Cooktops))
by JennairOven 12/8/2022 3:30:24 PM(UTC)
KitchenAid double oven - broiler working, oven won't warm (Oven Repair (including Ranges and Cooktops))
by jcz24 11/28/2022 5:53:17 AM(UTC)
Whirlpool Double oven diagnostic mode (Oven Repair (including Ranges and Cooktops))
by webjunk78230 8/29/2022 1:37:43 PM(UTC)
Frigidaire FGET2765PWE Wall Double Oven (Oven Repair (including Ranges and Cooktops))
by innesmd 7/1/2022 3:28:51 AM(UTC)
1970 GE electric wall oven (double oven) broken temperature sensor (Oven Repair (including Ranges and Cooktops))
by zea3 6/21/2022 1:48:00 PM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
Jenn Air Double Oven Malfunctioning (Oven Repair (including Ranges and Cooktops))
by Guest 12/27/2021 3:48:46 PM(UTC)
GE Double Oven Displays 'F97' Error Code (Oven Repair (including Ranges and Cooktops))
by Chainplate 12/2/2021 9:13:32 AM(UTC)
Double Oven- both fail to reach full tempo (Oven Repair (including Ranges and Cooktops))
by Guest 9/28/2021 2:38:45 PM(UTC)
