Has any one got a service manual for this refer? I need to trouble shoot a cooling problem and sure could use one. Thanks, jdeacon
Go to my comments in the above "sticky" GE (GS and PS ) model refigerators, your model has the same motherboard. Look behind the front kick panel for the service sheet.
Thanks for the reply richappy, I looked behind the front panel but no service sheet?? Some one must have remove it and didn't put it back???
Explane your problems with the unit, what's running/ not running
